1 - 20 of 97 Posts
Looks good! Tomahawk is right, do a little each day, take your time and before you know it you'll be planking. Being careful and accurate at this stage will pay great benefits later when everything is more fair. Sanding and fairing is probably the most tedious part of the job, so do everything you can to minimize that part of the job.
Thanks for the advice Tomahawk and Timm. That is my plan. I am a father of three boys so I go into the garage and start working after there mother and they go to bed each night. Wood working is my therapy. I should have named the thread. Confession of a night time boat builder.
I finished cuting another frame tonight. Trying to cut one a night. I also got the next two laid out.
Floor
Wood Font Plywood Floor
Wood Design Plywood Table Paper
Just curious: are these plans available so they could be loaded into a CNC cutter to make life much simpler and easier and less time consuming and cut perfect?
Jeremiah, I've been building the crystal 16 for the last year. It's been a huge stress reliever. Never believed that building a boat would be so much fun. Just to sit and have a beer at night and look at what has been accomplished. Keep up the good work.
Woodworking is a passion of mine. This is my first cold molded boat build. I built a stripper kayak a few year back and have been wanting to build a boat for a while. I will check out your build. Thanks for the post
Discussion Starter · #15 ·
Two more frames. Only two more to go. There is nothing like a little sawdust therapy to finish off the day. I love the look of the frames stacked up.
I've been able to work about two hours each night. I am hoping to keep that up.
Once the last two frames are done I get to start cutting on the 16' x 12" 6/4 mahogany. That should be lots of fun trying to control on the table saw.
Wood Plywood Floor Hardwood Wood stain
Wood Plywood Table
Wood
Wood Plywood Metal
Wood woodworking Carving
Wood Hardwood Plywood Lumber woodworking
That advice is priceless ...the end result of everything in life is based off the foundation it is built on ...take your time ... but hurry....
Someone asked earlier about CNC cutting. I do have cut files for the frames and transom. I have been working with two different firms for cutting and have also sold the rights on an individual basis to cut a boat using the files. If you want to have one cut, contact me through my website and I'll work something out for you depending on where you live. I am trying to minimize the shipping costs by cutting them as close to the builder as possible.
Jeremiah, the parts look great! Your family must be deep sleepers as the sound of cutting plywood doesn't wake them up!
Discussion Starter · #18 ·
I didn't get any boat work done last night but I used the time to clean up the garage and make space for the build.
Tonight I put together the two pieces that make the strongback.
The box didn't want to square up so I added corner braces.
Floor Wood Flooring Hardwood Plywood
Table Wood Furniture Plywood Floor
Wood Furniture Shelf Table Ladder
Wood Table Plywood Furniture Floor
1 - 20 of 97 Posts
