1 - 9 of 9 Posts
Always good
Discussion Starter #4
It is a 2 stroke, like my motor oil, this is the first time I have left my motor down out of the water.
http://www.microskiff.com/cgi-bin/yabb2/YaBB.pl?num=1309880672
http://www.microskiff.com/cgi-bin/yabb2/YaBB.pl?num=1327501728
http://www.microskiff.com/cgi-bin/yabb2/YaBB.pl?num=1288633370
50:1 is 50:1, pretty much the standard mix for a carbed 2 stroke outboard.
explanation from a previous post...
2 smokes are very inefficient at low rpms.
Up to 40% of the fuel/oil mix is blown out the exhaust, unburned.
Running at low rpms coats the inside of the exhaust housing
which will trickle down and leak out the gap between the lower unit and prop.
Always good
Discussion Starter #8
Ok yes I have been fishing the canals so idle every where so yes my rpms are down.. Thanks
1 - 9 of 9 Posts
