If you don't want to cut the factory leads, I would run the leads from the charger to terminal blocks close to your main battery, then make and run the necessary extensions from the terminal blocks to the trolling battery
That's good advice. Thanks. I'll post NOCO's response in a separate reply.If you don't want to cut the factory leads, I would run the leads from the charger to terminal blocks close to your main battery, then make and run the necessary extensions from the terminal blocks to the trolling battery
Note: I asked him to clarify that I can modify the leads by splicing into them and not void the warranty. He replied YES, as long as I do AFTER the fuse.Thank you for contacting NOCO Support.
The 14AWG leads of the GEN chargers can be extended up to an additional 10' without modifying or moving the fuse. The fuse must remain in place and the additional length must be added after the fuse. Absolutely no AC modifications allowed. The warranty will remain intact as long as these guidelines are followed. We do not provide information on extending the cables so you will have to research the appropriate cable and connections yourself. An additional fuse may be added closer to the battery for additional safety.
Sincerely,
Steve | Customer Support
The NOCO Company
I have a battery up front with my TM and my starting battery in the rear. I have a two-bank charger and cannot reach both batteries at the same time. I needed a longer lead (or option as suggested above). I will run an extension cord to charge and maintain the boat batteries when not in use. I will add an outlet so I can just plug the cord into the side of the hatch and will not have to prop open the hatch to feed a cord inside. Clean.My TM charger sits right next to the TM batteries then all I do is run an extension to charge. Is there not room to put the charger near the batteries or am I missing something
You don't need to charge the battery for your engine it should be charging the battery every time you run. Then you should have a cut off switch when your not using it
Yes, use adhesive heat shrink connectors and heat shrink over that. Recently did this for one of the leads to the cranking battery in the rear of boatI have the same situation. Were you able to successfully extend one of the leads? Thanks for your advice
