1 - 6 of 6 Posts
Going Solo .......
I finally had my first wet-test of my boat and engine. Boat is a 16' Fin and Feather, motor a '97 short-shaft 25hp remote Johnson. When I bought the motor I tested compression and got 125 psi on each cyl. When I had the engine set up I had tach installed so I could see what I would be running ....
When I took boat out for first run, engine starts and idles fine, runs smooth. And acceleration is OK -- not great but I think part of the problem is the prop -- it's a 10" x 15". It does get up on plane. But boat feels like it's not making top speed. I did not have a GPS or speedo so I can only go by feel -- felt like we were making high teens. The weird part was that the tach was saying we were only making 2800rpm full throttle!!
I was planning on taking boat back in to shop, but is there anything else I can do/check myself before turning it over to the pros?
AP
Living & Dying in 3/4 Time
I was running an 13 pitch on my LT25 with a Merc. 25 2strk, but it was a light boat. You may check the tach settings to verify it is on the right pole setting. What model tach did you install?
X2 15 sounds like a bit much ...
Going Solo .......
Gramps -- don't know model (shop installed it) but when I spoke to the tech he said you are probably right about tach settings. he also said if I was only making 2800 rpm I would probably not be getting up on plane.
So plan is to re-calibrate tach and try out a 10x13 prop.
Thanks everyone for your comments.
AP
Hi, my name is Jon and I am addicted to Fishing...
Agree with pitch being lowered. A lesser pitch will raise your rpm's but lower you top speed.
1 - 6 of 6 Posts
