I got a new tohatsu 20 and I’m wondering if I need muffs with the stock hose hook up already on there to get the water fully circulating?
If you are referring to the flush port, then no.
Also, I don't think it is recommended to run the engine while flushing - you can reverse the blades on the impeller. On my Merc it is not recommended. Read your manual.
Discussion Starter #3
It’s my first motor but I was under the impression that muffs allowed you turn on the motor and get the water circulating to the top? I’ve read the manual. I’ll go back again
What year is it? I've got an '18 and it doesn't have a hose hook up. I flush/run it with muffs.
I don't trust muffs, small set that were good on a 30 Rude slipped off my 2014 Hatsu 20, liked to give me a heart attack. Mine came with the hose adaptor but I like to get the engine warm when flushing. I slip a 32gal trash can under the lower unit, fill and fire it up, disconnect the fuel line until the carbs run dry. Pull the drain plug I put on the trash can and done.
Reactions: makin moves
By far the safest method and what I used to do with my 30 e-tec. That thing would never prime on the muffs.
Reactions: NativeBone
