Just saw it on Instagram. Cool to see someone do something completely different and outside the box. Weird that there is nothing for the company anywhere on social media.
Yea, running skinny is the only reason to run a jet.Not sure why the comments around "not running skinning"?
Sir Charles William Feilden Hamilton (a New Zealander btw) invented the Hamilton jet unit in the 50's with the sole objective of running shallow as rivers and streams were the main roads in New Zealand post WWII.
This is very much the norm in NZ. I've seen jets regularly run in inches of water. The need a pool to start in. I wouldn't think they would be very efficient. You can definitely hear them coming for miles. Basically a huge water pump. And yes, the suck up gravel, sand and seagrass and spit it everywhere.
Welcome to the club.
Running skinny in rocky hard bottom rivers are fine. That’s not a problem at all. But not over soft sand, pluff mud or grass. That is a huge powerful suction pump on the bottom.Not sure why the comments around "not running skinning"?
Maybe because it’s stated by the designer that it would be an issue?Not sure why the comments around "not running skinning"?
The inboard engine placement is a huge advantage for draft. Just have to shut down and pole up onto the flat. Which we probably should all be doing anyway. I think what we all need is a inboard/outdrive with a jackplate 😂Yea, running skinny is the only reason to run a jet.
Yea, that’s what mud boats and long tail or surface drive engines are for.Running skinny in rocky hard bottom rivers are fine. That’s not a problem at all. But not over soft sand, pluff mud or grass. That is a huge powerful suction pump on the bottom.
That is NOT what was written.Maybe because it’s stated by the designer that it would be an issue?
With me on the pole, any weight forward is a plus!The inboard engine placement is a huge advantage for draft. I think what we all need is a inboard/outdrive with a jackplate 😂
“Not an issue if you don’t fish the grass.”That is NOT what was written.
No turtle grass up here.“Not an issue if you don’t fish the grass.”
We all fish the grass, issue.
All grass.No turtle grass up here.
Tarpon tournaments and dolphin safaris, maybe sprinkle in a parasail here and there.Cool to see something new being tried in the skiff market but I don't see a use case for it in south Florida. Maybe it's a Texas boat?
