We officially have the new Cayenne 17 tunnel out on the water. We've spent 2 years of R&D to offer a shallow tunnel hull with leading 'V' forefoot that transitions to a zero degree deadrise at the stern. The result in a great ride in a chop while still allowing some serious skinny running on a plane. Poling performance is not compromised offering a 6" draft, superior tracking and spinning.
The idea was to build a skiff designed from the beginning as a tunnel poling skiff with a great ride. Point is, if you have a skiff that performs great, you just can't plunk a tunnel insert in the mold, make it a 'tunnel hull' and still have it perform at its best, either poling or carving tight turns on a plane in the back country. All the design elements must be considered as a whole if you want a great tunnel skiff.
And with cambered foredeck, slight reverse shear line and very large radius reverse transom corners, it looks pretty good too!
Length - 16' 11"
Beam - 72"
Weight - 340 / 400 (depending on build)
Max hp - 60
Draft - 6/7" 2 anglers & gear (depending on build)
Tiller, Center Console & Side Console
Skiff prices starting at $7355.....
www.ankonaboats.com
772.579.7214
Length - 16' 11"
Beam - 72"
Max hp - 60
www.ankonaboats.com
772.579.7214
