Need Plumber ASAP
Discussion in 'Off Topic' started by Michael, Sep 2, 2010.
  1. Michael
    Michael I Love microskiff.com!
    105
    We need someone licensed etc to check out our condo. The Condo association says we are causing a leak in apartments below us. The problem is that the shower that they say caused the leak has not been used in 10 years so the leak has to be coming from somewhere else. I need a pro to evaluate the leak ASAP. email mtd885@yahoo.com for my cell number.
  2. Gramps
    Gramps Living & Dying in 3/4 Time
    2,558
    31
    903
    Get ahold of Dave, NoeEttica.
  3. GTSRGTSR
    GTSRGTSR Well-Known Member
    517
    12
    393
    Where do you live?
  4. Michael
    105
  5. mark_gardner
    mark_gardner I Love microskiff.com!
    it is very possible that the shower is indeed leaking. its obviously not the drain as you state it hasnt been used in 10 years which that in itself is a cause for concern but a different point of discussion for a different topic but basically you have water lines that run in that wall that supply water to a valve and thats propbably where the water is coming from... my suggestion is to get someone in there asap to access the situation cause if you've never experienced a flood in a muliti level building trust me you dont want to ;)
  6. Michael
    105
    Have you got Dave's phone number?
  7. Gramps
    2,558
    31
    903
    MTD: PM responded to.
  8. Michael
    105
    Thanks all we found someone.
  9. mark_gardner
    let us know what he finds :)
  10. noeettica
    noeettica Well-Known Member
    3,708
    116
    2,268
    That's Good ...
    I left a message ...
    Take a 2 Foot level and Mark out a square behind the Valve ...
    Carefully remove square (shallow cut)
    Could also be water Dribbling Down a Vent Stack ...
  11. Michael
    105
    There is a crack in a pipe from our spare shower to the main pipe we are told we are responsible for. We found a guy who came out and verified it. I told the manager that I'm certain the water came from elsewhere because we don't use the spare shower, haven't had to in 10 years. The Plumber said that there's likely another leak above which drained down. They'll get wise when the leak continues even after we fix our pipe! If I had three wishes they would all be to get out of this condo. The condo board here are the nastiest, narcissistic and cruelest humans I've ever met.  :mad: Dave got your message, we found a guy to do the job. I appreciate the response...michael
  12. DuckNut
    DuckNut Brandon, FL
    4,691
    517
    1,968
    Dave,
    You a plumber? I have some work for you. Send me your number.
    Thanks
  13. mark_gardner
    you wanna run that shower every once in a while to keep water in the p trap (drain) otherwise it evaporates and allows sewer gases to enter the room...
  14. Michael
    105
    Thanks South Bound will do. I never thought of that! Since the cat box is in there (we change it every day) I never noticed anything! Live and learn!
  15. noeettica
    3,708
    116
    2,268
    Pull up the strainer and Install a test Plug EZ PEEZY
