Hello everyone I'm hoping some of you might have some thoughts and suggestions as to help me with my recent Carolina Skiff J12 build. I attached a few pictures below. I purchased the hull about a year ago and just recently bought a 2006 Mercury EFI 4 Stroke long shaft tiller off CL. With that said I mounted the seat and the engine myself. The issue I am having is I cannot get this boat to plane or get past about 10mph. The first time I took it out I was by myself and didn't have much time to test the boat so I launched at a local lake ramp and immediately was dangerously porpoising. I adjusted the manual trim pins all the way down but still was having the same issue. I realized that I didn't have enough weight in the front so packed it up for the evening and went home. Needless to say I just tested the boat for the second time yesterday and had similar results. The boat was not porpoising but the engine couldn't get the boat on plane even at full throttle.I had myself (185lbs), my girlfriend (125lbs), my dog (40lbs), gear (40lbs), and one 56lb sand bags in the very front storage. I figured with this 25hp Mercury that this skiff would be flying. Even loaded down yesterday, we where only able to go about 10mph and never get on full plane despite being at full throttle. I'm convinced there is something wrong. Either weight distribution, tilt/trim, or possibly engine not functioning at max RPM despite indicating max throttle on the tiller handle. Please let me know your thoughts... I will post a video later if possible.
