1 - 3 of 3 Posts
I've had my 2003 Nissan 70TLDI for a few months now and it has recently started giving me problems with the alarm going off. I have a tach with lights for oil, temp, and battery which all flash once on start up then stay off while running.
The alarm starts beeping within a couple minutes after I start the motor and will not stop. It's not a constant beeeeeeeeep... but just beep beep beep beep....etc
I have a 1000 cranking amp battery fully charged, plenty of injection oil and the motor is pissing great.
What could this be from? When I originally started using the motor I noticed that if I left the key in the on position while the motor is off for more than about 5 minutes the alarm would make the same beeping, could this be related?
Thanks in advance for any help.
The beeps and lights are diffrent codes for what the problem is check with the owners book I belive they break them down in there so you can figure the problem
Discussion Starter #3
Just read the manual from Nissanmarine.com and it says if the buzzer sounds frequently after restarting take it to a dealer...That ain't happenin' anytime soon. I don't even know of any dealers around here in Bradenton.
1 - 3 of 3 Posts
