Need help propping my ride...
2063 5
I have an 06' Gordon waterman 16' with a tunnel. With a 40 tohatsu tldi the current prop I am running is a warn 11" 12p with hardly any cup I can only get 52-5400 RPM 3B I had a custom prop builder build me a prop and he came up with this. 11" 10P 3B cupped. with the 12p I have seen 25 MPH but loose about 3-4 MPH with the 10p and gain about 2000 RPM with 20 gallons up front and 500lbs on the rear deck trimmed out jack plate with the 12 p cavitates if I raise it more than a 4 on JP and starts to loose water pressure and gives me a high temp alarm. I can run the 10p in shallow water on a 5.5-6 sometimes without an high temp alarm... Just getting frustrated... Any suggestions would be greatly appreciated.... Thank you in advance.
1 - 6 of 6 Posts
Am I reading this correctly?  A 2000 rpm difference between a 10 and 12 pitch.?
1 - 6 of 6 Posts
