I have owned a 13' Gheenoe for 30 years and love it....for what it is. But as a XXL 65 year old, it is not a stable platform for the kind of fishing I want to do. We have a place at a south Brunswick Co. beach, and I will be fishing local rivers and creeks, but have to access those places via the ICW. So I bought an older 1542 jon boat w/25 hp last year, and it was a huge improvement, but still a not as stable as I'd like (going from stern to bow to deploy trolling motor) and it drafts about 12" with motor up (heavy welded hull with 3 batteries and gear and my 280 lbs. I've been looking for a larger welded hull jon, but not much success, or at least at reasonable used prices. So, I started looking for a microskiff. I realize I will be losing some functionality as this will be a fishing boat only.
I found locally a 2000 Pathfinder 15T with the original Yamaha 40 2 stroke on the transom. I will be taking it for a test on Thursday. I have done the research and am aware that these boats have potential stringer/de-lamination problems. This boat has had the stringers replaced about 8 years ago, and the deck is rock solid. So not so concerned with that issue. The motor seems to run well, and cylinders check out at 105/105/100 psi. Comes equipped with almost new MK Riptide 55 lb. remote trolling motor (not iPilot), almost new Simrad 7" GPS/sounder; Power Pole (smaller version); stern poling platform which I will not be using; and 15' push pole. Current owner is 2nd owner, and seems very honest and open about the pluses and minuses of the rig. Seems to be pretty much turnkey, and is priced at about the same price as most of the jon boats I have been looking at.
I guess my questions are these: 1) other than the stringer issue, is there anything else I need to know about the 15T? 2) Will this boat do OK in a 1' chop? Will it handle rougher water at slower speed should I get caught out in a sudden storm? I realize it will be a wet ride, but I will be picking my days. Any other advise would be appreciated.
