Need fuel tank connector
703 7
I've got a new Quicksilver hose headed my way and I need to adapt the tank end to my Moeller 3 gallon tank. The tank has a male fitting on it currently, but needs female for the new hose. Anyone know of a fitting that will work with a Quicksilver 8M0061885 Fuel Line Assembly? Thanks!
-- Carl
1 - 8 of 8 Posts
Your local Merc dealer should have what you need (or have a part number...). Let us know if I'm right since this has to be an issue they've seen before... Failing that, go to a very well stocked marine hardware store, bringing your new hose with you for a bit of McGuyvering... which might just include a new end for that new hose - and a complimentary new fitting on that gas tank...
Bob,
Thanks for the suggestions. I tried the McGuyvering approach last time to get what I have now. I am suspicious that fitting is leaking, so I wanted to go with a Mercury one this time around. Probably asking for too much to match the tank and the hose end with one fitting. I guess I could do a short hose between a tank fitting and the mate for the hose. I like being able to detach the hose from the tank when I throw it in the car to fill up.
-- Carl
Premium Member
Use a brass hose barb
(from any hardware store)
If you don't need to disconnect it from the tank. No drips, runs or errors.
Wire
Spare tank, 3 gal Moeller I just happened to receive delivery of.
As much as I like the detachable hose assembly, it's just one more thing to fail. I'm leaning in the "hose barb with permanent hose" direction. Thanks for making me think it through!
And with the right size wrench it will take only a moment to remove that fuel hose and hook it up to a second tank if you keep one aboard...
I haven't had any motors that came with those "quick disconnect hose ends" in many, many years (I haven't run any small motors since the early eighties...) but I still remember how occasionally the quick disconnect ends would come un-done or allow air into the fuel line. Using a direct connection eliminates even the possibility....
1 - 8 of 8 Posts
