FGCI has everything you’ll need. Make sure you get a UV resistant epoxy like the instructions said. It’s a pretty easy process I plan on doing the exact same to my stiffy in the near future. Make sure you clean the pole off really good after you sand with 220. Replace the tip with a bolt and lock it into a drill or something to rotate it while the epoxy or paint dries.
