1 - 20 of 42 Posts
Okay well I just did the water pump last night and took it out today. There is something blocking the system! The alarm went off twice today, once before I knew there was an issue and once after I thought it was solved.
It'll pee great at idle but when I get up to higher RPM, it'll plug up. Then I'll reduce RPM back to idle and it's still plugged up. The problem was first noticed after scraping through some of the bottom (negative low today) at idle and it got plugged up.
I tried the high test line trick and it temporarily worked but that didn't last long.
I got back home and pulled the lower unit. I then vacuumed, back-flushed, and anything I could think of to the LU and water pump. No help! It keeps clogging for some reason...
So...was are my options here?
Stop running it in the mud and grass
Too true SW, too true... ;)
RK, you're going to have to flush out the block.
Possibly by removing the thermostat, or the exhaust cover.
You've pushed something up into the passages,
now you've got to figure out which one is blocked.
I've used compressed air, the vacuum cleaner
pipe cleaners, weedwhacker line, and parts removal
to find and eliminate clogs. Caused not by hitting bottom,
but by running through sargassum patches offshore,
and getting chunks sucked up into the outboard.
If it's not one thing, it's another.
Murph man you got some issues don't ya. At this rate we will never make it to Ft. D on the same days.
Discussion Starter #5
So I thoroughly examined the system of water flow through the block. Why did I get a 4 stroke again? One of the things I miss about the 2 stroke...SIMPLICITY!
It comes through the block (pending the thermostat), enters the "fuel cooler", and then out of the motor. ALL of these areas are very difficult to access and would probably require some major disassembling...or baby hands...
But, from what I saw, there is no reason why the back flush shouldn't have knocked it out...apparently my judgment doesn't mean anything, though.
I guess this is a project for tomorrow...if anyone wants to come over and help, let me know ;D
Keep the advice coming...and the "not running through sand/mud" is permanently noted... :mad:
Won &quot;Do More With Less&quot; Award!
U keep fugged up everything u use... ;D ;D ;D
U need me to come over or bring the boat over and I can help u out my my time is wayy too tight! ;D ;)
Oh I forgot.....
The most common to get clogged up with mud,sand, and weeds is the thermostat.
So before u do anything....just take the thermostat out and then bolt it back in.
Then run the motor with water hose and ear muffs in idle speed.
Let me know how the motor pee without the thermostat.
If it does pee really good then it's the thermostat. If not then it's something else.
Hope this help.
another thought but kind of a slim chance that the vanes on the impeller got damaged from the sand and a piece of it is clogging.
Another possibility is you put the impeller in with the wrong rotation and when you rev'd up the motor you shredded the impeller and one of the pieces got sucked up the tube.
Discussion Starter #11
I pulled the LU again and took the WP housing off. Everything looked great. Impeller looks as good as the day I took it out of the box...which just happened to be 2 days before :)
I pulled the thermostat and Shop-Vac'd in there...which I'm guessing would include the water jacket. I need to get a new gasket (which no one has, of course, so it has to be ordered) so I can test it.
I also pulled the top off the "fuel cooler" and Shop-Vac'd the passages in there (not the ones containing fuel, of course).
That's all I can think of...I don't know what else I could possibly do.
If this doesn't work, I guess I'll just have to take it in for warranty work. Hopefully they won't notice it's been "tampered" with.
RK, you better get a Saint Eligius medallion to attach to that block!
Maybe that'll exorcise the hoodoo that seems to be drawn to you... ;)
Can't hurt...might help... :D
Who's Saint Eligius? The Patron Saint of Mechanics! :cool:
Discussion Starter #13
Hahaha!! I like that idea! I've tried doing things the normal way (i.e. - proper maintenance, etc.) and I'm willing to try anything!
Anyway everything is bolted back up. I put some RTV gasket maker on the thermostat cover temporarily to test it with and without the thermostat in.
I ran it sans thermostat and there was very little water pressure. Which makes sense...
I revved the RPMs up pretty high and nothing seemed to get clogged.
Then I put 'er back in the garage, unbolted everything (again!), cleaned off the thermostat, cleaned off the surfaces, reapplied the gasket maker, and bolted everything back up. Now I'm just waiting for it to dry a good bit before test #2.
Cross your fingers...
Did you know that you can cut your own gaskets?
Before gasket kits in a box, it was normal to have a roll of gasket material in the shop.
You simply made what you needed on site, no waiting on shipping or back orders.
I remember tapping gasket shapes directly from car engine parts using a ball peen hammer.
Here's a how to...
http://www.explorerforum.com/forums/showthread.php?t=240437
not to make liight of the situation but i think i know more about mercury cooling now than i ever did thanks to the trial and tribulations murphy has endured, good luck getting it squared away dude :)
Discussion Starter #16
Well I ran the motor with the thermostat and here are some observations I made.
First, I know why the motor started to pee intermittently or quit at high RPM on the hose...the earmuffs would slide around due to vibration! [smiley=1-doh.gif]
Second, I fixed this issue by filling up a big trash can and running the motor in there. Here I was able to get the most realistic depiction of how it would be on the water, anyway.
Unfortunately, it didn't go how I had hoped...the stream is somewhat strong but still sputters and the motor seems to be running hotter than it should. It feels as if it's running hotter than my 2 stroke. I took the RPM up pretty high (probably close to max once on accident) and ran it for 10-15 seconds a couple of times at probably around 1/2 to 3/4 of max. It started to smoke a little but stopped when it idled for a few seconds. I also noticed that the exhaust housing was fairly hot, as well. I don't like how this is looking...
I'm going to call the dealer tomorrow and hope for some "warranty" work. Hopefully they're willing to work with me...can't be affording a big bill right now. :-/
keep in mind brother that the water is recirculating so the water going in the motor is continually getting warmer the longer you run it when you run it in a garbage can unless maybe your cycling that water out with fresh cooler stuff :-? :-/
Discussion Starter #18
I was. I had the hose going continuously when it was running to keep cool water in there.
Anyone have any other thoughts on what this could be? The issue wasn't present until after I did the water pump job...
hey murph not to sound like a jackass, but are you sure you put the impeller in the right direction? if it was installed in the wrong rotational direction it would pump some water but not alot.
I'm too tired to typed this...before I was planned about going to econ river today but end up cutting trees at the house in 6am in the morning and went to the zoo for few hours with a family.
Please Please don't trottle up 3/4 turn and that's cause mis firing over reving the motor that's can caused to smoke.
Just leave it to idle to 1/4 throttle when u running at home.
I hope u can take it to the dealer tomorrow and tell them u have warrenty on the motor. Just tell them u want to have them to check out through the motor completely.
Hope everything goes well.....
U need to get back on the water than worry about the motor went wrong all the time....;D.
1 - 20 of 42 Posts
