Hey guys so I recently got a Carolina skiff j12 and I wanted to put my motor I had on my jon boat on it...mercury 25 with a 15 inch shaft. The problem is the motor is a little too high. Maybe 2-3 inches max. I need to lower my motor bc right now it will not run because its too high. Should I use a jack plate or cut out the fiberglass?? Am I able to just put the jackplate on our will it not be able to tilt up when I need to trailer the boat or pole. Plz all input will help. I'm in Miami so if you also suggest local companies for this fix lmk. I was planning on using a bobs mini jack plate. Is this the right one??
Thanks!!!!
-Mike
Ps pics will be coming soon!!
Thanks!!!!
-Mike
