I have a 1992 30 HP Yamaha 2 stroke electric start that is currently not starting. It tries to start when I use starting fluid but immediately dies once it burns off the fluid. This makes me think it isn't getting gas. Also when I prime the bulb it gets hard but a minute after I stopped pumping it softens up. The first thought I had was a leak in a hose or a bad connection of a hose on a nipple but I don't see any signs of that and I can't see any fuel dripping anywhere. I also got a new gas tank just in case it had a small crack or had a bad vent because it was old. Could this be an issue with my fuel pump? If it is, should I replace the entire fuel pump or is there a specific part inside I should replace. Like a diaphragm or something? Is it something other than the fuel pump?
Thanks in advance for any help you can give me.
