2011 Mitzi Tournament 17, Yamaha 70F
$21,500
Upgrades and what’s included:
-Minn Kota iPilot 55 lb with remote & GPS tracking with Spotlock (includes Riptide quick release mount, group 30 AGM battery and 50 amp Minn Kota circuit breaker)
-Hydraulic steering assembly
-21 ft Stiffy guide push pole
-Flats Jac Hydraulic jackplat
-Garmin Echomap 74SV (all tracks included!), 2017
-Custom aluminum poling deck
-Custom aluminum casting platform
-Cavitation plate (Stiffy shaw wing)
-New Eddie Elite gear & throttle controls installed by Simmons
-75% rewired (including new fuse panel and switch panel)
-3 extra stainless rod holders on poling platform (in addition to the standard 6 rod holders in hull)
-Yeti mounts with straps for Yeti Tundra 32
-Swinging tongue Continental trailer [Trailer has been nearly completely rebuilt within the last year by McClain Trailers: New torsion axle, new hubs, new bearings, new bunk boards, new LED lights, new crank, 8 ply tires, spare tire, etc...)
-Shallow pole anchor and plow style anchor with chain
-Drift sock
-Livewell with pump
-Lenco Trim tabs
-Fusion Bluetooth audio speaker system
Dimensions: On the trailer with tongue retracted, boat length with from prop to tongue is 21.0 ft (but could be shorted by nearly 1 ft if you turned the motor and trimmed up further). Total width is 6 ft 10 in from outside-to-outside edge of tires. Height on trailer is 6 ft 6 in. Boat is 16 ft 10 inches LOA. Boat floats in 6 to 7 inches. Beam is 6’ 5”
Yamaha has 520 hours. Runs great, absolutely no problems. Cruising speed is 30 mph, even loaded with 4 adults on board. Gets on plane great too with 4 blade prop.
You’ll see boat is kept very clean: lower unit oil, engine oil/filter and fuel filters routinely replaced and kept up with. Top deck is spotless. I always flush the engine running it with the earmuffs (and not just the water hose). The tachometer is moody but I never refer to it anyways. I think one of the speakers is out, but its plenty loud without it.
I’ve trailered this boat to the Keys, fished the Texas coast, we camped in the glades and chased bull reds in Louisana. We’ve even enjoyed it on Lake Travis and Lake Conroe for a some summer time trips with the girls. It’s great for wade fishing (we’ll have 4 guys total in the boat and run from spot to spot.) It’s great for a 2 man fly fishing trip: And really is amazing trolling around with the iPilot (This minn kota can troll in about 1.5 ft of water!), two of us easily can fish from the bow at the same time; works perfect on the coast and in LA. We’ve had a great time with this boat as you can see.
Best way to contact me would be on a DM through microskiff.
Boat is located at my house in Houston, near 290 and 610. Serious buyers only please.
Thanks yall!
