Been working on a 2006 Mercury 15 HP 4 stroke that I recently got from someone that hadn't used it much in 2 years. Motor starts well every time, idles well, and runs well until around 1/2 throttle. After that, the RPMs seem to increase, but the speed doesn't. The motor also seems to shake substantially more. Pumping the bulb while running doesn't help.
Maintenance was long overdue, so I changed the fuel filter, oil filter, oil, and ran some Sea Foam through it. It seems to sound much better at idle and lower speeds, so I was optimistic when I took it out tonight for a water test. However the problem persisted. I think it could be a fuel issue, so considering changing the fuel line, but wondering if anyone had any opinions.
Also worth noting- it ran fine around three trips ago (the first two times I took it out). Reached much faster speeds with an extra body on board.
I'll see if I can post a video. The issue begins around when I reposition my hand on the throttle.
Many thanks, CP.
Many thanks, CP.
