1 - 13 of 13 Posts
My motor has been sitting for about 6 months, its a 96 9.9 2 stroke, I cant find anything online about how to change the impeller. Does anyone have a link or a writeup that can help me out? thanks
Plenty of vids and instructions available
http://www.google.com/#hl=en&sugexp=gsih&pq=change%20impeller%20mercury%20outboard&xhr=t&q=change+impeller+mercury+9.9+outboard&cp=28&pf=p&sclient=psy&source=hp&aq=f&aqi=&aql=&oq=change+impeller+mercury+9.9+outboard&pbx=1&bav=on.2,or.r_gc.r_pw.&fp=ff3e2739446bc197
Yes it will be good timing friday for sure, it will give me a good weekend project. Bought the motor used and there is no telling when the last time the impeller has been replaced. Thanks for the links Brett for some reason when I searched google it kept giving me links to 90hp and above engines even when I typed in 9.9.
Same basic process for large or small outboards,
or you can download an entire merc shop manual for your outboard
and go at it with step by step instructions, pictures and torque specs
http://www.microskiff.com/cgi-bin/yabb2/YaBB.pl?num=1288632807
Tips...
Use the free download option, download the desired rar file from the list, this one I think
http://rapidshare.com/files/213240334/6-8-9.9-10-15.rar
If you don't have a program to open rar files, you can download a free program called IZArc here
http://www.izarc.org/
When you extract the rar archive using IZArc you'll be asked for the password: "ribforum"
The section for lower units/impeller installation is in the number 6 pdf file
Yes, I tested the process to verify it worked, see?... ;)
I downloaded the program and opened the file but my computer will not uncode the program when I open it, it just has a bunch of random numbers and letters, I'll try to have a friend open it for me on their computer.
As a side note, and once you get done replacing your water pump you should always keep a length of weed-wacker/trimmer line in your boat or tackle bag. It's thin yet stiff enough to get up in the motor's pee hole to clear obstructions when it's not pumping water.
I coil mine up and zip tie it to something under the seat/console. Bright orange so it's easy to find when you need it!
It can save the day, or better yet, your motor!
1 - 13 of 13 Posts
