Does anybody know if I remove the cracked/leaking built-in fuel tank under the cowling will the engine still run off the external tank?
It seems like when I squeeze the ball fuel is pushed up through the fuel line and enters the built-in fuel tank (you can see it enter the top and fill the tank up) so I am thinking there may not be a fuel pump in the outboard and the fuel comes directly from the tank and gravity fed to the motor?
