merc 25 impeller?
2097 7
How long should it take for the motor to start "peeing" when I flush it? It seemed fine last time I was out, but when I flushed it, it took a while. Maybe no hotter when it did but by the time it did I was done with the flush. It's a 2001 25hp 2 smoke that I got from a friend who had never had the need to do anything to it. Any help or answers appreciated!
1 - 8 of 8 Posts
Get an OEM shop manual and it's easy. Part is ~$15-$20 and then you'll know the last time it was done. Careful when you check the thermostat, though. Though bolts will break! Get a couple torque wrenches, grease the bolt threads, and retorque them to ~90% of what the manual calls for.
Oh and you might as well replace the gasket and o-ring on the water pump and thermostat...they cost cents on the dollar.
My rule of outboard motors is replace the impleller once a year, along with the lower unit gear-oil.
But my son has a 2004 Merc. 25. 2 stke.. and it has a thermostat.. many times when we flush it it take a few minutes for the engine to come up to temp, we alos have a temp guage, and the theermostat to open.
If you watch while you are flushing, the engine should discharge water from the pee-hole tube, then stop.. this also happens on the water also. Depending on the temp of the water supply it opens and closes at different rates.
I pulled the Foot My impeller Looked liked new ... But NO big Impressive pee stream not running hot ... New Motor ...
also have a small motor ...NO big pee stream ... Impeller like new ... run motor does NOT run hot .... So be it
Dave
Hey thanks for the replies, I got the manual and seems that it has thermostat, it does mist before it comes on, so that explain it. I have ordered one and the appropriate gaskets and should complete it this weekend. Hoping to get pics of it up soon as I have never posted pics of my skiff. Thanks again!
1 - 8 of 8 Posts
