1 - 9 of 9 Posts
I have 1997, 2 stroke, 25hp, mercury, tiller that I got with a beat very beat up prop. The prop on the motor says 48 19640 A40 13p, then lower it says 9632x. Is this the stock prop that came with the motor? I want to purchase a new oem size prop. I am happy with the performance as is but think it is unbalanced. Any other suggestions??
I love my microskiff
That is a stock merc prop for that lower unit by the numbers you gave.  Yes, likely came with the engine.
I put cheap Solas stainless props on all my small outboards, and am running a 13 p solas on my merc 25 now.  I am very happy with the performance.
Living & Dying in 3/4 Time
13p in aluminum should treat you well, might need to go down to a 12 or 11p in stainless.
Like a broken record, I'm a huge fan of Turning Point props for performance and price point. :cool:
Discussion Starter #5
I found a used stock mercury prop for 35.00. The prop paint is peeling but the metal is perfect, not even any dings. Hopefully this works out.
I also found out my motor has plastic prop nut??
Discussion Starter #7
How tight should crank it down? Right now it is hand tight then one turn.
I honestly have never looked up what the actual torque specs are for it. I'm sure they're in the service manual, but I just crank it down until it's snug, then apply firm but not excessive pressure to the ratchet until it stops.
Discussion Starter #9
Thanks, I could not find the specs in my manual but it should be fine.
1 - 9 of 9 Posts
