1 - 10 of 10 Posts
Just put a new 9.25 x 7p prop to try and get motor into max recommended rpm range but only reach 4300 rpm out of my 2 stroke Merc 15hp. Scratching my head here.
Discussion Starter #3
I believe I had a stock prop that was on it before. Numbers were on unreadable. I believe a stock prop is a 9.25 x 9p. I felt.like the motor was revving all the way to leak power so I put the 7p on it and a little tach. I had to move forward in the boat with a tiller extension to get on plane. Got on plane once I moved forward in the boat and reached a peak of 4300 rpm. The boat is a Martindale.
That’s strange. You sure your tach is set to 2 stroke? With a small boat I would think 9-11 pitch would be the zone. 7p is like a kicker prop right?
1 - 10 of 10 Posts
