1 - 20 of 42 Posts
Discussion Starter · #14 ·
sweet ride...do you mostly stand and run? Seems like it'd be tuff to sit and run.. the helm looks way high..?? Just curious! Good Luck!!!
Thanks!
I had it built slightly higher than a standard console. I do stand about half the time while running. I wanted to build a really small leaning post for the driver but plans have changed with the new house.....
Discussion Starter · #20 ·
Is the new sea deck you just added covering up the hole in the floor now? I see you also deleted the original pics.
Are you interested in the boat or just asking a question?
The "Hole in the floor" is from the factory, its a wiring chase. When I raised the console it was left exposed. The floor under the seadeck has some spots that were rubbed smooth by the old console in the non skid that did not look perfect. I have a 4" access hatch cover that can be cut in the seadeck if the new owner wishes.
1 - 20 of 42 Posts
