what should i do to maintain a 15 hp johnson motor.I cant afford to take it to a mechanic right now but would like to know what i could do myself to keep it in good working condition.
Read and follow the instructions in this one...
It covers just about all the basic maintenance needed annually.
It's a pdf file so you can save it to your hard drive as a permanent reference.
I use the lower unit lube purchased from my local Merc dealer.
But any quality lower unit oil will do the job.
Even the stuff from walmart, I think it's Lubrimatic.
What is important is regular inspection and changing,
but using the same brand oil each time. Don't mix lower unit oils.
Don't forget to replace the drain screw seals also.
They get old, split and leak.
