View attachment 165658 View attachment 165659 View attachment 165660
Hull 2018 lt10 olive with tan interior.
Quick slick under coating
Grab bar with cushion
Insulated Center box with sea deck
Front and rear deck with hatches
Yeti cooler tie downs on rear deck(cooler not included)
Onboard rod holders
Nav lights (not wired in)
Trolling motor mount with steak out
45LB Minn Kota riptide trolling motor
Duracell deep cycle battery
Carbon marine mangrove 16ft push pole
Bilge pump
DIY pvc tiller extension
2018 Swing Tongue Continental trailer from Gheenoe
Radial high speed tires
Mounted Spare tire
2015 Mercury 9.9 4 stroke
Fresh plugs, oil, and lower unit oil done recently
Impeller done about a year ago
Stingray jr hydrofoil
3 gallon gas tank new fuel line
I only run rec 90 in the motor and it gets flushed after every use.
Newer solas prop have the original as a spare, also a 4 blade prop that's never been used.
Vance manufacturing manual adjustable jack plate.
Transom saver,emergency paddle and misc. parts included.
Located in Miami,Florida.Asking $6300.Contact (786)307-6547 text or leave a message if call is missed.
