1 - 9 of 9 Posts
16 Bonefisher
I have a Lowrance LMS 337 that was working fine. I was running back through a little rough water the other day and it started flashing bright then dim and beeping so I turned it off. I got back to the house to check it out and it will not power back on. I unhooked the power wire and hooked it back up. I changed the fuse and checked the wires it all looks good but will not power on. Any suggestion?
Thread Killer
have you tried looking up the issue on the lowrance website?
16 Bonefisher
The reset worked, thanks for the help. What size fuses are ya'll using? One of the local boat dealers here told me to use a 4amp but they keep blowing. Can using too big of a fuse hurt the unit at all?
Thread Killer
per the Lowrance website, 'a 3 amp fuse should be used, anything more will void the warranty'
I use the 3 amp on my HDS gen 2 and have not not any issues
check to make sure the connections are clean and are corrosion free, you may have a little corrosion in the pin connectors (very difficult to see), if not new, then try a new power plug for the unit
Really bad idea to keep upping the fuse size, a fuse bigger than specified can definitely damage your FF.
The fuse is blowing for a reason, not a good one either. Check the wiring and make sure there are no nicks/cuts allowing it to shorting out. If everything looks good try wiring directly to the battery by passing any switches, bus bars, or breakers.
1 - 9 of 9 Posts
