SOLD/EXPIRED Looking for a ram lin trailer
Discussion in 'Sold/Expired Classifieds' started by Sheremeta, Aug 29, 2011.
  1. Sheremeta
    Sheremeta Well-Known Member
    I am looking for a black ram lin trailer for a LT 25
  2. Gramps
    Gramps Living & Dying in 3/4 Time
    2,558
    31
    903
    Check with Brad or Kevin at IPB / ECC, they had one for sale a while ago. If you're just looking for a nice torsion axle trailer check with Float-On or Continental, they both make a very nice aluminum frame torsion axle trailer and it may even be cheaper than a Ramlin.
  3. Sheremeta
    thanks, I am looking for a cradle style trailer so I dont have to "climb" into by boat while its on the trailer. I would also like to launch without getting the hubs wet.
  4. TheBrazilNut
    TheBrazilNut Guest
    To me having a trailer be more $$$$$$$ then my hull doesn't make sense. Ram-lin does not sell straight to the public unless you get a connection.
  5. Lt25
    Lt25 I Love microskiff.com!
    195
    Check the old posts in the classifieds.  There was a black one on here or the CG site a while back.  Better check with the CG shop because I don't believe they will fit if it's setup for a gladesman!  The LT is too wide for the ramlin that's setup for a gladesman.
  6. Sheremeta
    Good point. So finding a used one would be next to impossible. A new build would be around 2k, almost half the cost of the hull.
  7. gasman311
    gasman311 I Love microskiff.com!
    47
    Maybe showing my ignorance here, but why a torsion axle trailer for a hull that weighs way less than 1000 lbs?
  8. Sheremeta
    Adam. You are 100% correct but I dont want one because of the axle, I want the boat to sit as low as possible on the trailer.
  9. TheBrazilNut
    TheBrazilNut Guest
    there are some things to the basic continental trailer to make the skiff lower.
    Switch to 8" tires
    flip the axle
    OR
    find a used Hells Bay Gladeskiff and keep the trailer and sell the hull. ::)
  10. Gramps
    2,558
    31
    903
    I know I'm derailing, I apologize...
    Have you ever towed a boat with a torsion axle? The suspension actually words, the boat doesn't get beat up by the trailer. There was a place I had to cross rail road tracks heading to the ramp and every time slowed to a crawl otherwise the trailer & boat would nearly launch off the road. Do the same with a torsion axle and the boat/trailer bumps but doesn't act like it's ready for lift off.
    Besides, the torsion axle allows the trailer to sit much lower. If you just want a low trailer, do what B-Nut said and save a load of cash.
  11. Snookdaddy
    Snookdaddy Well-Known Member
  12. Lt25
    195
    This is the one I researched and was told it will not fit an Lt-25.  You may be able to do some modifications to make it fit, but as it is i was told it will not work.  Just FYI!
  13. swaddict
    swaddict Thread Killer
    693
    43
    403
    this guy is selling a classic with a ramlin trailer, maybe you could find out more info from him
    http://orlando.craigslist.org/boa/2567799713.html
