1 - 4 of 4 Posts
Microskiff.com... Priceless!
7DACA42E-4913-4F85-AA7D-6190826405DB.jpeg 7DACA42E-4913-4F85-AA7D-6190826405DB.jpeg 62B6F0EA-57CB-444F-B75E-3445B69FF38C.jpeg C528ABDE-18D9-4ACD-AA0D-D67DFBE32F21.jpeg A09E4559-2D7F-4D58-A443-813A87943B40.jpeg C4D36D39-050C-4466-B70F-AC6C42BE235E.jpeg 9BB699BE-8C40-4221-9FC0-B5E9F51C4841.jpeg EB84B938-47FF-4FEC-B807-85C5432352B9.jpeg 05B31069-C556-4708-8222-7C25F37B8C0F.jpeg FFC512EE-B065-47B1-9E9B-95E49D4676A0.jpeg 2F2DA424-3382-430F-9003-D2F3A5F0AB1C.jpeg 2014 custom gheenoe lt 25
-composite transom, no wood like standard gheenoes (I supplied the material when the boat was built)
-Foam filled floor, custom upgrade
-Awlgrip paint inside and out (no need to buff) custom upgrade
-New seadek
-Jack plate
-Fold down polling platform to get into small creeks
-tibor push pole holder
-yeti 35 for casting platform
-removable center box with 3 mounting locations. The Box stays water tight thanks to the seadek.
-removable grab bar, holds the yeti 35 or a 45
-55lb minn Kota trolling motor and group 27 battery with breaker.
-removable trolling motor mount
-lumitec dimable Red/White LED deck light
-lumitec dimable Red/White LED flood light under platform, bright enough to piss the neighbors off
-Black LED nav lights
-LED anchor light
-12v plug
-on board battery charger
-brand new battery
-brand new bilge pump
-lowrance hds5 GPS
-21' pushpole
-6 gallon quick release fuel tank
MINT 2003 25 2 stroke
-new water pump in the last 3 months
-new thermostat at the same time
-ss 13p prop
-boat runs 33 mph empty with me by myself
-registered until sept 2019
I built this boat before I moved to the keys specifically to fish the Everglades and do some camping. The boat is set up to remove everything to haul gear as a utility vessel. Endless possibilities for lay out. The motor fired up on the third pull after sitting for a few months. The only reason I'm selling is I bought another boat and don't use this one much. Asking $7500 obo text is preferred but open to calls. 3215434045
Boat is located in Titusville FL
Motivated to sell but no low ball offers please
1 - 4 of 4 Posts
