Yes that’s the one I have. My line shows like 235gr for a 8wt
Rio, Wulff and Monic are typically 1rod wt heavier than what the line is stated. Lines like SA, Cortland and a few others try to stick with a normal weighted fly line+/-. So keep that in mine. Some newer to fly casting, picking up ultra fast and or stiffer rods prefer the "feel" of a line that is 1 rod wt heavier than the actual rod. Also the same with freshwater fisherman from up north that is use to a slower action freshwater rod, that then picks up a faster, stouter saltwater rod and then prefers to over line it by 1 or 2 rod wts to get that same action they are use to in the rod. But that being said, it resembles going to a rod 1 line weight heavier than what you are holding in your hand.
The trick is to get a line fitted to either what you need for the fly, the distance and the conditions according to rod weight you want to use, or learn how to cast a true to weight fly line, and adjust your casting and the fly size to the distance and the conditions, needed.
No doubt we can spend pages of discussions on this thread about the subject in all camps, but also, there is no doubts too that their are many different rods, different styles of rods, using the "correct fly size and weight of the fly," as well as many casting styles to achieve what you are trying to target in those specific conditions. The fun comes in where you are able "through experience" to dial those things in to accomplish what you set out to do, preferable by skill and not necessarily by luck.
So, there is
no do-all rod, with a do-all line, using a do-all fly, with a do-all casting technique, in a normal conditions to catch any fish that swims.
For me, after all those years throwing the buggy whip around, I've reduced it down to just the basic few outfits that cover most of what I'm targeting. Same with lines. I also have no problems throwing a slightly heavier line on a faster or heavier rod, when conditions call for it, but casting rods with some feel to it, throwing any sort of distance with true to weight lines with flies correctly size for those lines, are my preferred setup.
Ted
