Any have any preference?, need to replace mine
What's undesirable about auto retract ?Seems like a number of builders are going to either the electrotabs or the bennett volt tabs. I have the electrotabs on my skiff now and really like them. Quiet, quick and no auto retract
I dont like them because you are having to reset the tabs after you just had them where you wanted them plus they sound like an old garage door going up. At least my buddies Lencos did. I am sure it can be argued auto retract has its place but they just arent for me.What's undesirable about auto retract ?
The reset cycle makes a bunch of noise. If your tabs don't touch your trailer or lift it's easier to just clip the wire.What's undesirable about auto retract ?
You got me all confused with this. You say the auto retract is nice and you go on to explain why yet at the same time you say you have the retract orange wire clipped ???????Auto retract on Lencos is nice because you don’t have to wonder where your tabs are when you crank up to move to another area and also so you don’t have to run them up when you stop to pole. Who poles with their tabs down and why would you want your tabs to stay in one position? I am constantly using my tabs to jump on plane, run over shallow areas and adjust attitude in chop. I understand that everyone has their own ways and opinions. Maybe I’m using my tabs all wrong? I have the auto retract orange wire clipped, both ends capped and zip tied together in case I want to add a switch to turn that function on and off.
I clipped it to add a switch to turn it off so I can shut down and not have them auto retract every single time I turn the ignition off. I haven’t added the switch yet because I had a few other upgrades to do that were more important. I was also adding that because some folks seem to be under the impression that the auto retract feature is a big deal to disarm. The new dual switches with the built in “computer” and auto retract function are not as easy to disarm. I have the separate box that was an add on to the regular Lencos. I don’t want tab position indicators either, just more crap to buy.You got me all confused with this. You say the auto retract is nice and you go on to explain why yet at the same time you say you have the retract orange wire clipped ???????
Bennett’s still require power and nowhere on a boat is it free of moisture and humidity.Having worked in the electronics manufacturing business most of my life, I have an aversion to
components situated in a wet environment. That's why I don't use Lenco tabs. Bennetts are pretty much fool proof, providing the pump is mounted in a fairly dry location and protected with
anti corrosion spray.
