Like all lighting products, what's advertised usually isn't what you end up with.
Compact fluorescent bulbs were supposed to be cheaper to run and last longer
than a comparable incandescent bulb. But in reality the initial cost of a pack of
CFB's is much higher than a similar sized pack of ICB's. Lifespan of the CFB's
hasn't been better than the old style ICB's. Then there's the disposal problem
of all mercury vapor products. With LED's, the advertising is based on the original
design specifications that were developed in the research labs, but production bulbs
are made using cheaper quality materials, components and don't use the original design.
http://www.energystar.gov/index.cfm?c=lighting.pr_what_areBad design can lead to a wide range of problems, some immediately observable and some not. Poorly designed products often come with exaggerated claims while failing to deliver on the quality specifications
