looks like it need a new pine needle to poke!~Install new fuel hose while off shoot some carb cleaner into the fuel inlet in carb and let run out of bowl ... sometimes works ... otherwise new needle 'N seat and bowl gasket ...(clean main jet while U R at it
Dave
So HE'S the one with the leaky gas?The prop is fine!
The problem is usually with the nut attached to the tiller.
Float valve not functioning properly would be my guess.
The needle is probably gummed up and not seating.
I'm happy and sad. I'm glad Whitesnooky got his motor running, and happy Brett (again) was right, but this means my diagnosis of the prop pitch being off was incorrect.Float valve not functioning properly would be my guess.
I was right!
I was right!
[smiley=chicken.gif]
I'm so easily entertained...![]()
Well you kids be careful and don't get your fingers caught in any timing belts while you're tuning up that little 4-banger.Brett,
U assume that's a guess the needle is not seating property.
It's takes only 1 and half hour to do it then it's all good.
It's a lot easier than I thought to rebuilt it.
Now I'm gotta prove NoeEttica that 4-stroke are not dogs! Prop her right and boost the carb then it will scream like a mothercrappity smacker.
I wll like to play the NOS spray into the 4 banger!Well you kids be careful and don't get your fingers caught in any timing belts while you're tuning up that little 4-banger.Brett,
Just in case you guys blow it up while installing an intercooled procharger or something Dave's got my old little 8-horse as a backup.
U should know I'm playing with ya!Ohhh Shrek ! That realy cut me ...
Somehow I sense another carb leak coming.....U should know I'm playing with ya!Ohhh Shrek ! That realy cut me ...
NoeEttica,
What propeller are u using on your 15hp with 13footer? 9 x 8 4 blade with cupped?
Just curious to know.
