1 - 6 of 6 Posts
Im starting to redo the transom on my 13 and have a couple pieces of coosa to use. My plan is to use fasco 110 to attach the coosa to the transom skin. Should I laminate the coosa on both sides then fasco it or can I fasco it to transom and lay glass once its adhered? My thoughts are that if i just fasco and then lam it i wont have to worry about any delamination from my poor workmanship:)
Why use two different resins?.
Fiasco is expensive compared to other resins. You will also need to buy resin when you cover it so why not just buy a half gallon kit and do it all at once?
I already have a gallon kit of the 110. I assumed it was mixed to a putty consistency and it would not work into cloth very well. I'm also adding a section over the ankle breaker. Are you saying ditch the fasco and use something like 105? I have some cabosil so I could make a putty for adhesion...
110 is a putty that you could use to bed the foam in place.
No, 110 will not work with cloth.
You will only need a pint of the gallon to bed the piece.
You will need to buy resin for the cloth. Use cabosil to thicken and use that to bed the piece in place.
3/4 of the gallon will go to waste. Return it and get resin.
WS 105 is great stuff but expensive. www.raka.com will save you money on resin and cabosil.
1 - 6 of 6 Posts
