SOLD/EXPIRED Kubota GL-6500s Low Boy Generator
Discussion in 'Sold/Expired Classifieds' started by Amsoil_Man, Jul 13, 2013.
  1. Amsoil_Man
    Amsoil_Man I Love microskiff.com!, And it Loves me back!
    200
    For Sale: Kubota GL-6500s Low-Boy Diesel Generator -- $2,400 OBO (No Trades).
    http://orlando.craigslist.org/for/3932922752.html
    Generator has been meticulously cleaned and maintained since purchase date. Serviced recently with oil and battery replaced. Less than 300 hours total on machine. Diesel is extremely reliable over gasoline powered generator cranks on the first turn. Optional 2-Wheel kit makes moving easy. Get it in time to prep for the hurricane season.
    Specs:
    Generator
    Model GL6500S
    Type Rotating field single-phase AC generator
    Frequency (Hz) 60
    Maximum Output (kW) 6.5
    Rated Output (kW) 6
    Rated Voltage (V) 120/240 Dual Voltage
    Rated Current 50.00 / 25.00
    Number of Poles 2
    Power Factor (%) 100
    Engine
    Type Kubota horizontal liquid-cooled 4 cycle diesel engine
    Model ZB600-GL-S
    Rated Output (HP/rpm) 12 / 3000
    Displacement [cu in (cc)] 34.78 (570)
    Number of Cylinders 2
    Fuel Tank Capacity [Gal (Liter)] 5.02 (19)
    Engine Oil Capacity [Gal (Liter)] 3.17 (3.0)
    Cooling System Pressurized radiator, forced circulation with water pump
    Starting System Battery assisted electric starter
    Noise Level (dBa) Approx. 68
    Emergency Stop Mechanism In case of abnormal oil pressure or water temperature
    Accessories
    Model GL6500S
    Pilot Lamp Standard
    AC Voltmeter Standard
    Fuel Guage Standard
    Key Switch Standard
    Glow Lamp Standard
    Monitor Lamps - Oil Pressure, Battery Charge, and Water Temperature Standard
    Idle Controller Standard
    Ground Fault Circuit Interrupter Standard
    Circuit Breaker Standard
    Full Power Switch Standard
    Automatic Voltage Regulator Standard
    AC Repectacles Standard
    Dry Battery Standard
    Center Hook Standard
    Hour meter, control panel cover and lock, side door lock, 2-wheel kit, remote-control unit, thermostat kit* Optional
    Contact at (407)-496-4938,
    -Ben.
    Location -- Orlando, FL.
  2. Amsoil_Man
    200
