Are u going to replace the plywood core in d floor? R did u check it n see if core is good? Boat is nearly 50 years old, I had a 1969 model like it. Was a great little hull. Good luck with ur build.
So that’s a cored hull??Are u going to replace the plywood core in d floor? R did u check it n see if core is good? Boat is nearly 50 years old, I had a 1969 model like it. Was a great little hull. Good luck with ur build.
As of yesterday I didn’t know I had plywood in their for sure. But I do know now. Thanks bud100% yes.
Picture 2 shows drain channels along perimeter with a raised center. This does not match the hull contour.
This was covered in your other thread about this.
At this point I don’t even know if it’s worth it I don’t even know where to begin to be honest with you.Time for a tear out!
Sounds like time to splash d ole girl, lot of interest in the hull on this site. Higher tech today layup should come in at under 200# vs original weight of 300+#.I think that’s what I plan on doing being that old of a boat I’d rather not just dump too much money into it
Let me know before trashing itI think that’s what I plan on doing being that old of a boat I’d rather not just dump too much money into it
Patch the holes and finish your build. If the floor showed no soft spots it will last several year.I took a 5/16 paddle bit made sure that everything was clear around where I was going to drill,Made a few small holes in the floor,Took the shavings and put them on a piece of white copy paper let them sit for a few minutes once I took the shavings off I saw moisture spots on the paper,same for the transom
Well it doesn’t look like it but I still have to flip the hull and repair the bottom so If for some reason I can see a void should I fill it with 2 part foam?Did u have a gap below the plywood core? Reson I ask is I had a similar situation n injected foam in void n used the hull four more years n sold her...
