1 - 11 of 11 Posts
I have a 71 Kennedy craft 13’5. I want to paint the bottom and topside. Im proficient in painting using hvlp guns but I know boats are a different monster. What do you guys recommend for prep,primer and paint??
Epoxy primer inside and out. Two part polyurethane outside finish. One or two part polyurethane inside finish. Jamestown distributors have both and tech support.
Banned
Kiwi Grip for non-skid. It's easy to use and easy to repair. Agree with above--epoxy primer.
Topcoats--a little more specific. If you want it to last it needs to be a linear polyurethane. Not all two-parts are created equal. These are very good and popular in the industry:
Alexseal (acrylic linear polyurethane)
Axalta Imron MS-600 (acrylic-polyester linear polyurethane)
Awlgrip (polyester linear polyurethane)
Awlcraft 2000 (acrylic linear polyurethane)
US Paints Sterling (polyester linear polyurethane)
Definitely! Will be painting outdoors weather permitting. I know that stuff can give off bad fumes
Not only fumes but breathing the microscopic particles will cure on your lungs.
Without a fresh air system I would never attempt them, even then I would have to exhaust all other alternatives.
1 - 11 of 11 Posts
