1 - 13 of 13 Posts
Clean fun in dirty water!
Hey All,
I am hoping to pull from your collective expertise. I love the look of SeaDek but I don't have it in my budget right now push another $1K into my boat build.
Has anyone experimented with any success with alternative materials? Am I crazy for looking at yoga mats, and industrial foam flooring, etc...?
No offense at all to Castaway Customs or SeaDek intended.... I would love to be able to afford the beautiful product. Hoping for a temporary alternative until it can be budgeted.
The inside of my boat is a bright and clear finish on a custom built Indian River Skiff (Bateau plans modified) so I didn't want to go the non-skid paint route.
Thanks for any suggestions!
Lee
I made some pads to absorb shock by the rod holders and it broke down and started crumbling within 2 months. If you look you can find seadeck in smaller pieces and end lots on different sites
Chris,
Does Ocean Grip come with the peel off adhesive backing? If not, what did you use to secure it to the deck?
Thanks!
Ocean grip has the 3m backing... You make the templates, mail it to them and then install yourself... Fairly easy process... My j14 has it on the front deck, inside the boat on the floor, on the rear bench, on my poling platform and I had a few reel pads made too. It's like waking on a sponge, it stays grippy when wet too...
It's extremely similar to seadek... It's prob the same stuff..
Oceangrip is not cheaper than seadeck and is almost double the price of hydroturf. The hydroturf full sheets are larger as well 47x86 vs 39x78. Even if you get the hydroturf with the PSA backing its still substantially cheaper. Its not that bad to use the contact cement and its actually easier to remove and clean up than the backing.
The seadeck and oceangrip are more "finished" looking though.
You can make the hydro turf have a "finished" look... Just pic up a router, someone on MS or CG had made a diy router table and cut all his own seadek... You could do the same with hydroturf..
There is another brand out there called gatorgrip. It's more like foam pebbles, cool stuff but I'd think it's better for a wakeboard/swim platform than inside a fishing boat...
Discussion Starter · #10 ·
Thanks for all the great advice. I ended up ponying up the bucks and went with Ocean Grip. I originally tried to purchase sheet goods from Seadek only to find out that they will not sell the dual color sheets in the raw. For multiple reasons I needed to do this as a DiY project.
I have yet to install them as I am still cutting my decks this week. I will put up a post on the brag spot as soon as I have some pics put together.
I love my microskiff
1998 AC 1890 / 2022 Gheenoe Classic
Yep- ordered some hydroturf and going to try this out. I got twice the amount of hydroturf for the money compared to seadek. I will post up how it turns out. They have blemished sheets with minor air bubbles and stuff (not a big deal if you ask me) that is great for inside hatches and stuff. Very economically priced, comparatively speaking, and I have heard the longevity is good.
Discussion Starter · #13 ·
Tomahawk,
I had the same problem! I was looking for a sand or sage green color and hydro turf had neither. They used to have it and discontinued it because to your point it faded terribly to a muted gray color.
I will post some pics once I get the Ocean Grip put down.
Lee
1 - 13 of 13 Posts
