stupid question time. Need to remove to untwist ( binds when tilted ) port side line. Never done this. Bled plenty of brakes tho. Anything to look out for . Seems strait forward. Thx ahead of time.
There’s no pressure on the system unless you move the wheel. Remove fitting and keep hose end above helm (where the pump is) and you shouldn’t lose any fluid. Have a couple of towels ready just in case. You will need to bleed the system after as you will introduce air when removing the fitting. Follow Seastar hydraulic system bleeding procedure.
