1 - 6 of 6 Posts
I recently purchased a Gheenoe 15'4" highsider.  I plan to sand down the hull fix any damage and repaint.  I am curious to know about how much paint it would take using the roll and tip method.  The amount of paint used will effect the quality paint I will be using so having a ruff estimate before hand sure would help.
I'd say a quart should do the trick.
firecat1981,
    What did you thin it down for.  Was this for purposes of spraying or did you roll it.
Make sure you get the brushing thinner. They make spraying thinner and brushing thinner.
1 - 6 of 6 Posts
