1 - 20 of 37 Posts
Hey guys I've been looking for a 14ft Kennedy craft hull to mount my 50HP OMC short shaft on. Has anyone put this much HP on one of those hulls? I'm worried about how much freeboard I will have at the transom when it is in the water.
If it is the little V hull skiff, 20-25 HP is what most of the skiffs like that were rated for. There were 6-7 makers that built essentially the same skiff.
that’s
Well u came to the right place as I had 2 different engines on 13' kennedy kraft, 1969 purchased in Pensacola. Built a mahogany side console using factory console for pattern. Added a mercury s/s 35 hp 140# 2 stroke n ran for a while. Sold motor n put a new 50 hp 165# 2 stroke s/s merc manual n used it for years. No issues with boat r draft issues. Could pull 2 skiers.
Discussion Starter · #10 ·
Did it list a lot to one side with that side console or was it stable enough? I tried the same set up with my 50 evinrude on my 14 ft Collins craft and it was way too unstable. Had no freeboard and listed way too much on the starboard side with me in it.
I hate to get rid of the motor. It's pushing 150 psi on both cylinders and runs great. You are right though it's probably too much weight.
When I was a kid the guy who lived next to us (we lived on a big lake) mounted a 33 hp johnson on a kennedy and used it as a ski boat-it was fast enough to barefoot ski behind so approx 40 mph. but within a year the boat was sway backed and would chop at any speed.There isn't enough back bone in those boats to withstand that kind of weight and strain.
I’ll be in a bay. May be better for me to just get a 25hp.
Go to US coast guard site, look for the boat builders guide and it will tell you how they calculate HP capacity, its length x transom width, and there is a table that tells you the Hp range, they also allow more HP if its console steered rather than tiller. I'm not sure if the CG would care if you legitimately have a hull without the rating plate, if they inspect you they might look for it but if it wasn't there when you got it seems legit. I cant imagine that it would be a boat buyers responsibility to recreate one if the manufacturer is long past, it can get involved.
Discussion Starter · #15 ·
According to my GPS that I have set up on it I’m running around 23 to 25 miles an hour depending on the wind and the water surface. I wanted to go bigger when I first got the boat but after taking it out I think that my 18 hp two-stroke is plenty fast enough to get me where I need to go. Normally I travel with a 35 quart yeti fully loaded with ice, rods and reels, tackle and a full 6 gallon tank of gas. Plus my bodyweight . I will be installing smart tabs on the transom to help with the lift out of the hole. I’m having a little bit of porpoising But once I install the tabs and re-locate the battery towards the front I should be good. Do you have any pictures of your Kennedy craft?
1 - 20 of 37 Posts
