How do you all make your trailer bunks?
2570 5
We always uses 2x6 pressure treated lumber with outdoor carpet stapled to it. It worked well until it rotted out or the hardware rusted through... or both... about every 3-4 years. However, I have seen a few trailers here that look like they were made with different materials. I will be fixing up a trailer eventually and was curious what the options were. I'd like to make my bunks around 10" wide and 9' foot long with another cross support halfway between the end of the bunk and the winch.
Nate
1 - 6 of 6 Posts
I have 2x10's under the Slipper, works fine.
Use true galvanized hardware or stainless instead of cadmium plated.
Monel staples to attach carpet to your bunks.
Melt/rub canning wax into the bunk carpeting, it'll keep moisture from rotting the material
and make for easy launching and retrieval as the wax cuts friction to a minimum.
Don't launch your trailer, that's the easiest method to increase it's lifespan.
I have a small trailer (13-16ft). Currently it has pressure treated 2x4's covered in regular carpet. I was considering replacing with that polymer (plastic) decking material. If it is too thin I would bond two together. I only need them to be about 36-40 inches long. Then I would carpet and wax as Brett mentioned.
What do you think about using the synthetic decking material?
Brett, where do you get canning wax??? :-/
Mostly Harmless
I've looked at the composite decking.  I don't know that it requires more supports, but I strongly suspect it does.  I knew a guy who used some type of composite boards for the bottoms of stock trailers after the factory wood floors started to rot.  It sounded great and isn't supposed to break down over time, however he had to double up the cross members.  Plain ole wood still maintains strength over more cycles than most other materials and it is easily the most cost effective material, but I keep looking and asking just in case there is some new material out there that doesn't rot.
Nate
I've seen aluminum jon boats riding on un-carpeted bunks made from plastic wood.
Don't see why it couldn't work for you....
http://www.google.com/#sclient=psy&hl=en&biw=1280&bih=579&source=hp&q=trailer+bunks+from+plastic+wood&aq=f&aqi=&aql=&oq=&pbx=1&bav=on.2,or.r_gc.r_pw.&fp=905e9081899b75b1
1 - 6 of 6 Posts
