How do read this Powertech prop?
Discussion in 'Prop Shop' started by backcast, Jun 22, 2020.
  1. backcast
    backcast I Love microskiff.com!
    182
    68
    353
    I am not sure how to read this “engraving” of this Powertech prop. I have it on 2008 Caimen and I was able to get hole shot with Bob’s jackplate all the way up. I did not have water pressure gauge at the time so not sure about water pressure. Got one added so I will see if can run that high and keep pressure. Hole shot was impressive.
  2. fjmaverick
    fjmaverick Well-Known Member
    1,277
    761
    728
    Looks like. I had a powertech and it looked like the same thing.
    SWC4R1CPY553
  3. NativeBone
    NativeBone Well-Known Member
    923
    1,380
    248
    First few letters is the model/style
    4= 4b
    10p=pitch
    All you need to know:cool:
    fjmaverick likes this.
  4. backcast
    182
    68
    353
    No. Could not make out if SWC or SWD.
    Joe
  5. backcast
    182
    68
    353
    I looked at Powertech site and for 50hp there was no prop listed with SWD but it sure looks like a D rather than C. But has to be C.
    Joe
  6. backcast
    182
    68
    353
    Got shaw wing on, water pressure gauge and tachometer. The prop slips at WOT . It holds grip at lower throttle but WOT slips. I have bobs jackplate up all the way and Caimen pops up nicely. I can slow down to about 17mph and prop holds. that’s at 2000rpm. I am puzzled by the max rpm at WOT shows 2900 rpm. I thought lower pitch would increase rpms. The water pressure is 22 with jackplate all the way up. I think the tach is reading accurately because at idle is 800 rpm. Also had porposing problem on my first run, on this second run I put trim tabs down about 2/3 of way and helped a lot but did not totally stop proposing. I will try again with tabs alll the way down next time. First time with boat having trim tabs and did not know what to expect.
  7. State fish rob
    State fish rob Well-Known Member
    1,172
    1,335
    718
    Get some cup added to your prop, you should be fine. Tabs too low could be picking prop outta the water at speed Play with set up every which way.
