How are guys getting back in skiff?
Discussion in 'General Discussion' started by Megalops, Aug 12, 2017.
  1. Megalops
    Megalops Rex Kwan Do Dojo
    1,126
    456
    948
    Thinking about doing some scalloping Friday. No problem getting in skiff waist deep water, my concern is 6ft plus deep. I'm pretty sure I could "rocket" out of the water with fins and flounder on front deck. My concern is older and inexperienced guests. Do they make a simple rope ladder that I tie to poling platform? Any and all ideas welcome.
  2. damthemainstream
    damthemainstream Active Member
    67
    32
    43
    I've used the cavitation plate as a step on some larger outboards before.
  3. Smackdaddy53
    1,243
    1,005
    718
    If I saw anyone stepping on my cav plate I'd lose my mind...
    A rope ladder sounds like a great idea.
    Backcountry 16 and Megalops like this.
  4. damthemainstream
    67
    32
    43
    What would it hurt, in your estimation.
    Megalops and Smackdaddy53 like this.
  5. mangoman
    mangoman I Love microskiff.com!
    41
    31
    343
    I mounted the ladder bracket to the stick pin anchor plate and it is very easy to step and pull yourself out using the poling platform.
  6. firecat1981
    firecat1981 BBA Counselor
    5,021
    260
    1,938
    Megalops likes this.
  7. makin moves
    makin moves Well-Known Member
    1,588
    140
    918
    I do the one hand and leg over the side and pull and roll in. Its not pretty! It works though or go to the back corner and grab the poling platform legs and pull myself in. You have higher sides on your boat so it is alot more challenging.
  8. Smackdaddy53
    1,243
    1,005
    718
    Motors aren't steps
  9. firecat1981
    5,021
    260
    1,938
    On a bigger outboard it's not a big deal. On a smaller there could be a chance of damage, and the cave plate is tiny.
  10. RunningOnEmpty
    RunningOnEmpty I Love microskiff.com!
    608
    161
    168
    I've always used the cavitation plate as a step. The smallest outboard I've done this on was a 1980's johnson 15hp. Those old omc's were built pretty heavy duty though.
  11. Smackdaddy53
    1,243
    1,005
    718
    I'm picturing someone my size (230#) stepping on my compression plate that is bolted to the cavitation plate on the lower unit. Either way I don't think the transom, tilt/trim or jackplate needs that added stress. Some of you guys that are 140 pounds soaking wet may not be that bad. I just don't think the motor is the best place part of the boat to use as a step to board the vessel. I guess I'm just being silly.
    Megalops and makin moves like this.
  12. tjtfishon
    tjtfishon Well-Known Member
    169
    44
    103
    ^That
    How much force do you think the motor is putting on the transom to move the boat...and that is mostly perpendicular to the transom, not straight down where all the strength would be anyway. An assist step on the cav or more likely splash plate is nowhere near your full weight. I mean you have to be pulling yourself up...it isn't possible just to step on the lower unit without some grabbing and pulling yourself onto the boat...unless you are pulling yourself up by the cowling which I still don't think would be a big deal.
  13. RunningOnEmpty
    608
    161
    168
    I was considered skinny @ 200lbs so I'm far from a little dude.
  14. Smackdaddy53
    1,243
    1,005
    718
    This is why I have a two man skiff, one person is easier to babysit than 3-4...let me guess, you guys slam ice chest lids and step on the cushions with dirty feet too?
    Megalops and fjmaverick like this.
  15. RunningOnEmpty
    608
    161
    168
    Sometimes I don't even wash my boat after fishing all day LOL. I'm more concerned with flushing my motor and keeping it maintained. I was a professional finisher so my boats are like a blank canvas. No matter what happens I can always make them look like new again. I actually hate taking care of gel coat because it gets stained so easily vs a high quality 2k finish like Imron or Awlgrip.
    Smackdaddy53 and Megalops like this.
  16. Megalops
    1,126
    456
    948
    IMG_2995.JPG IMG_2996.JPG Thanks everyone. I went with this rope ladder from BPS. What do you think? Strapped to poling platform. Or do you think to front clear? Reason is my skiff squats and when I take a leak off back darn near can dunk the stern.
  17. BM_Barrelcooker
    BM_Barrelcooker I Love microskiff.com!
    99
    132
    358
    I use a foam pool float.
    It's nice to sit on in the cockpit too.
  18. Battfisher
    Battfisher Well-Known Member
    174
    41
    103
    Best option I've seen yet. I did a simple rope ladder which worked fine for me (6'3 and 180#), but not for my son who is not athletic. The rope ladder wants to swing under the boat so it takes a little core and upper body strength to use it. I think you'll see this with the BPS rope ladder.
  19. westsidefly
    westsidefly I Love microskiff.com!
    178
    41
    103
    Did EastCape do that for you?
  20. lemaymiami
    lemaymiami Well-Known Member
    2,012
    822
    1,318
    Enjoyed the various ideas then thought about what you actually face in the real world... For me the most important thing is to be able to assist someone getting back into my skiff - after they've gone over the side without intending to... I've done this a few times (usually the hard way, under bad circumstances - even late at night in a hard current...) -on one occasion with an elderly guy who could barely assist me at all...
    This sort of stuff is always best at the stern of any boat where the freeboard is at its lowest point -and if you need the motor's skeg or even a trim tab (at the point where it's closest to the transom) as an assist -it's better than not being able to get back into the boat....
    Once or twice over the years it's been me, solo, needing to get back into the skiff with no one around at all - and every time I've said a prayer of thanks that I wasn't injured or disabled at the time. It's enough to make you think twice about the possible hazards we face on the water...
    By the way - I long ago learned to kick away from the boat if I came off the poling tower - since the motor, prop, and edges of trim tabs would tear you up in the wrong set of circumstances...
Loading...
Similar Threads Forum Date
fly guys trolling motor opinions... Fly Fishing Jul 3, 2017
Hi Guys from South Africa Introduce Yourself Oct 6, 2016
New guys from Baker Fl Introduce Yourself Sep 24, 2016
Tarpon in the Lowcountry - want to go fish for these guys? Fishing Reports Aug 20, 2016
Question for you guys that dry launch.... General Discussion Aug 15, 2016
