1 - 20 of 21 Posts
I can't seem to find any online. Do they have a technical name that would sweeten the google search parameter, as of now hook pull is pretty vague.
Thanks in advance guys.
Lowcountry Degen
No need to drop lots of coin unless you like the look of the eye bolt -- you can just use a quality stainless pad eye. Slightly larger footprint, but I think it's much stronger. I can tighten knots in 80# leader without worrying about tearing anything up. Two machine screws with big fender washers makes for a very study base and spreads the load over a good bit of fiberglass.
Not saying that the eye bolt will ever fail or cause the glass to fail, but the pad eye does the same thing for around 5 bucks.
I Love Skinny Water
I think i can get a stainless eye at Ace for less than $5. I think ill mount it right in the middle of my foam hook holder
This is what I just purchased for my Vantage. SS eyebolt, fender washer and a couple hex nuts to set the depth and tighten and then the other for a jam nut. All in about $6 from West Marine.
Key chain, mount it in a plastic console hatch, cooler, pliers, buddies arm, casting platform mounting hardware or Boga grip. Hey it’s your boat. I’ve never see it, or thought of doing this. Although I did make one for tackle box for land based jetty fishing and heavy tackle.
Alternatively you can attach a split ring to whatever device you use to cut your leaders and line when tying. Lots of "knippers" come with them already, common with fly fishermen.
1 - 20 of 21 Posts
