Sure enough.  Little perfect pinhole.  Are these motors supposed to have a relief hole or is this a possible cause of my pee troubles.
Me sticking a small paperclip in it.
Over time, heat and acidic exhaust gases will eat the tube.
I've had to replace 2 tubes due to erosion of the metal.
Old outboards with a lot of hours.
Its the most perfect hole is what gets me. I guess ill have it soldered because otherwise the pipe looks good.
Solder may be a great temp. fix, however I'm sure there's some corrosion going on elsewhere on the tube. I'd go ahead and order a new tube just in case the solder turns out to be only a band-aid.
