Help Viewing GPS with Polarized Glasses
Discussion in 'Power it up with Electronics' started by csnaspuck, Dec 6, 2017.
  1. csnaspuck
    csnaspuck You got to get burned to learn
    236
    95
    153
    I apologize if this has been asked before but has anyone tried to use a film on their GPS to help them see the screen when wearing polarized glasses. I came across NuShield when trying to find a solution online. Anyone have any recommendations?
  2. mtoddsolomon
    mtoddsolomon Lip Ripper
    1,185
    1,137
    718
    I don't really ever have a problem seeing my screen. I use smith mirrored amber chromopops if that matters
  3. EvanHammer
    EvanHammer I Love microskiff.com!
    87
    63
    93
    What GPS are you using? I've also never had problems seeing any of my units
  4. csnaspuck
    236
    95
    153
    It is a Simrad Go7. Maybe I just need to change the brightness but I have a hard time seeing the LCD when wearing my Costas.
  5. EvanHammer
    87
    63
    93
    I'm not familiar with that unit but some units that are marketed for marine use are harder to see in bright sunlight than others. Crank the brightness up, but if that doesn't work do some googling and see if others are having trouble seeing that same unit.
  6. Egrets Landing
    Egrets Landing Well-Known Member
    101
    46
    103
    It has to do with the glass on the unit and the polarization in your glasses. If you get a different pair of glasses with the polarization the opposite of what your current glasses are it may fix your issue. To see if this is it, next time you go out and have a problem, take your glasses off and turn them exactly 90 degrees from the angle you have when wearing them. Then look though one of the lenses and see if you can see the screen better. If that is the case, you will need different glasses with the glass set in the lens like that. You can take the glasses that are causing the problem to the store and hold them up to the potential new ones and look through both at the same time to see if they are cut the same or or different.
    csnaspuck likes this.
  7. Cam
    Cam Well-Known Member
    125
    66
    53
    Newer units from pretty much every manufacturer generally do not have this issue. Older models of pretty much every unit do. They all seem to have changed the glass in the units and reoriented their polarization to be more compatible with sunglasses.
