HB Pro Side Console
2473 26
Going really basic on this one with bare bones guide green side console Professional with Tohatsu MFS60 on galvanized trailer.
Although the folding backrest/step is extra $, and I’m having the fuel tank made a little smaller so it doesn’t extend into the hatch opening.
Also deleted carpet, live well tub and plumbing. But that’s it for a one page build sheet.
I’m going to miss the size and speed of my Marquesa on some days, but I’ll be able to go places the Marquesa couldn’t go.
Naval architecture Boat Wood Rectangle Boats and boating--Equipment and supplies
Green Automotive tire Natural material Artifact Tire
Shipping box Motor vehicle Bicycle Package delivery Wood
1 - 20 of 27 Posts
Wish'n I was Fish'n!
Discussion Starter · #14 ·
Dishware Plumbing fixture Tap Serveware Porcelain
side console will have H2O pressure gauge, key switch, kill switch, nav light & bilge pump switches in the angled area on the front. Tach will go just above that leaving all the rest for me to add cup holder and BalZout mount for 12” Simrad later.
Naval architecture Radio telescope Gas Flooring Composite material
often imitated.
Hood Composite material Gas Asphalt Tints and shades
hatches are ready
Hood Motor vehicle Vehicle Boats and boating--Equipment and supplies Boat
worth the wait
Hood Motor vehicle Bumper Automotive exterior Automotive design
molded non skid is just right for bare feet
Wood Rectangle Material property Stairs Composite material
I’m putting my battery, fuse panel, and 12v/USB outlet in this center compartment instead of having a life well.
You can also see the transom material is different, and very hard for bolting engine, lifting eyes, power poles, and trim tabs through it.
Rectangle Wood Water Hardwood Composite material
I also learned that the space under the false floor in the outside stern compartments is filled with flotation foam.
Discussion Starter · #18 ·
HB sent a couple more pics today.
Water Composite material Flooring Concrete Building
Wood Naval architecture Boats and boating--Equipment and supplies Composite material Vehicle
Good call putting the heavy stuff in the center compartment. I wish mine was set up that way. Will help when running solo.
I’m hoping so…had a 2014 side console Waterman with livewell in the center that listed a little to starboard.
Discussion Starter · #20 ·
How does the molded non-skid compare to Awlgrip? I assume the mold will last longer but does it ever need to redone and if so, can you still just apply Awlgrip then?
I think boat builders like having the non-skid in the mold because it eliminates variations, reduces labor and material costs, and shortens build time.
Longevity is inversely proportional to usage with either, but according to the guy that rebuilt my Pro Line gel coat lasts longer. He uses his experience with commercial fishing boats as evidence for that. And so that’s what I have on my Pro Line. Although it’s not nearly as uniform or “pretty” as the non-skid jobs I’ve seen Jonathan Glasser do with Awl Grip over gelcoat.
1 - 20 of 27 Posts
