Hi everyone, my gunnels have heavy oxidation and some cracking. Any ideas how to correct this? Products and process for a noob? See pictures.
Premium Member
Hard to really tell from the pics whether it’s paint or gelcoat. But here is my take on it... needs to be stripped down with 60-80 grit and re done! Nothing will bring that back to a nice finish!
If gelcoat, was either applied too thin or over reduced and applied too thin, and or done in direct sunlight!
If paint, I’m guessing a one part and or oil based product again done in the sunlight.
Both paint and gelcoat the surface prep was probably sub standard as well. Sorry, but all I have for you IMO is it needs stripped and redone.
Thanks!
Would evercoat one step premium gelcoat or Petit EZpoxy work for this?
Premium Member
Thanks!
You are in Florida. Find a supplier such as Fiberglass coatings, Fiberglass Florida, Etc... and go buy your materials from them. No, I would not recommend either of the products listed. That’s a whole lotta work to go through to try to save a couple pennies on materials. If paint I would go with a quality 2k urethane over an epoxy primer.
Ok great ! I’ll reach out to them. Thanks!
